Chatflow API: conversation read endpoints and echo webhooks
Status: Closed · Asked by Willy Ng on · 0 views
Hi Willy,
Thank you for reaching out and for sharing the detailed requirements.
Below is a point-wise overview of the current Chatflow API capabilities:
1. Incoming Message Webhook — Supported
You can configure the New Message Received webhook under Chatflow → Settings → API & Webhook. It sends the incoming message payload to your external webhook or Pabbly Connect workflow.
2. Conversation History & Draft Replies — Not Currently Supported
The Chatflow REST API currently provides 33 endpoints covering messaging, templates, broadcasts, contacts, media, settings, and catalogs. Kindly refer to the Chatflow API docs page link attached below:
https://apidocs.pabbly.com/chatflow
However, it does not currently provide APIs to:
Retrieve complete conversation history or list conversation threads.
Create internal notes or draft replies programmatically.
Receive webhook events for outbound messages manually sent from the Chatflow Business App/Inbox.
Additionally, chat records are currently available within the Pabbly Chatflow Inbox for the last 30 days only.
3. Tags & Custom Fields — Limited Support
The API supports basic contact management and tag-related operations. However, there is currently no API-based AI mechanism that can independently analyze conversations and automatically create/update tags or custom fields based on the conversation context.
4. MCP Server — Not Currently Available
Currently, Pabbly Chatflow does not provide a native MCP server or direct MCP integration/configuration option, including a draft-only mode.
Recommended Workaround
Your proposed AI workflow can still be implemented partially using Pabbly Connect:
Use the New Message Received webhook to capture incoming messages.
Send the message content to an AI model such as Claude or OpenAI for summarization and draft-response generation.
Send the generated summary/draft to an internal channel such as Slack, email, or Google Sheets for manual review.
Once approved, use the Chatflow API to send the final response to the contact.
For the missing capabilities such as conversation-read APIs, outbound echo webhooks, draft replies, and native MCP support, we recommend submitting the requirements on the Pabbly Chatflow Roadmap for consideration by our product team.
Please let us know if you need any assistance with setting up the supported AI workflow through Pabbly Connect.
Shekh Dilshekh
Customer Support Specialist
🎉Black Friday Early Access
Hello there,
I hope you’re doing well. I just wanted to follow up regarding our last message.
Hello there,
I hope this message finds you well. I’m following up on my previous message. Further, this is our last follow-up. This Forum thread will be closed automatically as we have not received a reply. You can start a new thread or email us at support@pabbly.com to raise your concern.
