Clever way to recognize label names and use the data
StevenG
We use an ordering system and this system provides input through a webhook. Different fields are supplied but almost always with the same label name. This allows us to use the webhook for different products. However, there are two labels that keep changing so I am forced to build a different webhook for each product. 'Raw Custom Fields 113987' and 'Raw Custom Fields 11448'. The number in the label name keeps changing. It used to just be field 1 and 2 but unfortunately this has changed.
Is there a clever way so I can use those 2 fields but not have to build a new webhook for each product? For example that Pabbly recognizes a part of the label name 'Raw Custom Fields' and then can use the data from this field?
ArshilAhmad
Moderator
Hi @StevenG,
Will the numbers after 'Raw Custom Fields 113987' and 'Raw Custom Fields 11448' always remain the same?
If so, you can add a Router to your workflow in this manner and achieve your use case.
Recognizing only a part of the Label is not possible.
