Code by Pabbly preview fails with a regular-expression syntax error
Status: Awaiting reply · Asked by KANHAIYA PRASAD on · 0 views
A small JavaScript action (~1.4 KB) ran successfully in a live workflow. Two larger versions (~11.4 and ~11.7 KB), containing regular expressions including Hindi characters, fail in "Save & Send Test Request" with: "SyntaxError: Invalid regular expression: missing /". The first was entered by typing, the second by pasting. Both parse and run locally under Node.js after reconstruction from the saved configuration. Failed previews do not appear in Task History.
Are there code-size or Unicode/regex limits? Does preview process code differently from live execution? How can we see the offending line for a failed preview?
