Connecting ProProfs to Mailerlite
I am trying to connect ProProfs to Mailerlite, but ProProfs is not listed in the applications list. You have documentation on how to do this, no I know it connects to ProProfs, but if it's not in the application list, then how am I supposed to connect those two???
ArshilAhmad
Moderator
Hi @MonicaWalston,
Currently, we don't have trigger events for the ProProfs application. If you would like a specific ProProfs trigger event added to Pabbly Connect, please submit your request on our dedicated platform: https://pabbly.featureos.app/b/Update-Existing-Application
Our integrations team will review your request and, if feasible, add the desired trigger event to Pabbly Connect.
In the meantime, if ProProfs supports webhooks, you can try using Webhooks by Pabbly to connect with it in the trigger step
