Anson
Hi Support,
Is it possible to allow Connecting WordPress Blog using XML-RPC?
As in the free plan of Wordpress.com, we cannot install a plugin to connect the blog.
Please consider adding this feature, as currently in ContentStudio app. Thank you.
Connecting WordPress Blog using XML-RPC - ContentStudio Help Center
Follow the step below to connect your WordPress Blog using XML-RPC 1 Before using this method, make sure XML-RPC is enabled on your Wordpress website. Some web
docs.contentstudio.io
