Data Not Passed Properly to Woo-commerce
dataforge
Workflowname - Repairshopr Product to Woocommerce
Task ID - IjY3NTM2NzEwIg_3D_3D
Why did it failed and why it does not show any data in "Data In' of step Replacing Double Quotes and Woo-commerce ?
Everything is mapped correctly as per my understanding.
Supreme
Hey @dataforge
It seems like you have mapped the product name with the trigger response which wasn't converted from " to ''.
Though we have remapped the correct fields and did correct the 4 steps of your workflow. Further, we have tested the workflow in your account and now it is working fine.
dataforge
1. Workflow was working totally fine for items with " as well till now, why sudden failure and we did not made any changes at all.
2. What other 4 changes you have made in the workflow?
Supreme
Hey @dataforge
In the 4th step, you replaced the same double quotes with double quotes, where you should replace the text with double single quotes.
