GCalendar timezone issue.
Status: Closed · Asked by group on · 0 views
The settings on calendar is +01:00, however.
See the images.
See this last 3 history:
Workflow: https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY4MDYzMzA0M2M1MjZjNTUzNzUxMzAi_pc
Task History ID - IjU3NjMwNTZiMDYzNjA0M2Q1MjZmNTUzNzUxMzA1MTYzNTQzNyI_3D_pc
You have to change the Timezone from your "Google Calendar" action event since the data you are providing is already in Dhaka, so you do not need to change the timezone from your Google Calendar action event. Kindly change it to UTC to balance the Timezone when the event gets created.
However, with the help of Date Time Formatter, you can change the time zone to your desired timezone accordingly. Kindly review your workflow once we have made certain changes to it accordingly.
I have elaborately described everything here: https://komododecks.com/recordings/qVYS9DxwPhaDQJccOpvC
You can add a Date/Time Formatter to your workflow, subtract 2 hours from the time, and then map that time in Google Calendar.
