How to route a LeadSquared trigger to a WhatsApp Group using a personal number?
Status: Closed · Asked by Joshua Paul on · 0 views
Joshua Paul — Question ·
Hi Pabbly Support Team,
I am trying to build a workflow with the following requirements, and I need guidance on the best action app to use:
  • Trigger: LeadSquared (LSQ) event.
  • Action: Send a message to a specific WhatsApp Group.
  • Constraint: The message must be sent from my own single WhatsApp number, not via the official Meta Cloud API (since the official API does not support group messaging).
Pabbly Support — Reply ·
Hello Joshua,
Thanks for reaching out and for clearly outlining your requirements.
You're correct that the official WhatsApp Cloud API / Business API does not support sending messages to WhatsApp groups. To send automated messages to a WhatsApp group, you need a provider that explicitly supports group messaging. All messages are sent through Meta, and its official provider is the WhatsApp Cloud API.
Unfortunately, this use case is not possible, as sending messages to groups, whether you want to use your own number, is not allowed by Meta, as there is no particular endpoint to perform this action.
Adeel Akhtar
🌐 Pabbly.com
Signature image
