How to Track Node-Level Logs, Enable Retries, and Use REST API Integrations in Pabbly Connect?
Status: Closed · Asked by Wellness Vibe Tech on · 0 views
Wellness Vibe Tech — Question ·
I have a few questions regarding workflow monitoring, logging, error handling, and API integrations in Pabbly Connect:
  1. Node-level logs & deduplication:
    How can I track and store logs for each individual node/step in a workflow? I want to maintain important execution logs so I can identify duplicate executions and prevent deduplication issues.
  2. Advanced logging:
    Is there any way to implement advanced/custom logging within a workflow to capture important details such as request data, response data, execution status, errors, and timestamps?
  3. Single-node retry:
    How can I retry only a specific failed node/step instead of re-running the entire workflow? Is there a built-in option for single-node retry or error handling?
  4. REST API / Advanced API integrations:
    Where can I find the REST API/Webhook/API Request node in Pabbly Connect? I want to connect APIs that are not available as native Pabbly integrations and need more advanced options for handling API requests, authentication, headers, parameters, and responses.
I would appreciate guidance on the recommended approach for implementing these features in Pabbly Connect, especially for production workflows where detailed logging, deduplication, and error handling are important.
Pabbly Support — Reply ·
Thanks for reaching out. Here's guidance on each of your points for Pabbly Connect:
Task history logs are automatically retained in your account for 15 days, after which they are purged. Bulk/direct downloading of historical logs or workflow data is not supported. For polling triggers, de-duplication is automatic — you don't need to reset it manually. If you want to keep detailed per-step logs beyond the 15-day window, the recommended approach is to log errors/data directly inside the workflow, for example via a Router fallback path that writes to Airtable or a database.
2. Advanced/custom logging:
There is no built-in advanced logging module, but you can implement custom logging inside a workflow by adding action steps that write request data, response data, execution status, errors, and timestamps to an external store (e.g., a database, Google Sheets, or Airtable). Note that failure email notifications are capped at one email per workflow per day, so parsing those emails will undercount repeat failures — logging inside the workflow gives you full fidelity.
You can re-execute failed steps without re-running everything. Go to History > Task History, click the specific Task History ID/row, then click Re-execute in the top-right corner. You'll get two options: 'Entire Workflow' (re-runs all steps) or 'Failed & Skipped Steps' (re-runs only the steps that failed or were skipped). Additionally, Auto Re-execution can be enabled in workflow settings so failed tasks retry automatically, and each action step has an 'Ignore Error' option to continue past a failed step.
For APIs that aren't available as native integrations, use the Custom API request (API by Pabbly) action, which supports custom headers, parameters, authentication (including Token/Bearer), and response handling. The response body becomes the step's output and is mappable downstream. Maximum payload size is 6 MB. For reference, see the API documentation at https://apidocs.pabbly.com/ and the integrations list at https://www.pabbly.com/connect/integrations/.
General best practices for production: use separate workflows per use case, add proper error handling, monitor Task History, and test in a staging environment before going live.
Adeel Akhtar
🌐 Pabbly.com
