I need to trigger two workflows from same trigger column
Status: Open · Asked by Terapeut Online on · 0 views
Thanks for reaching out!
Each workflow you create has a unique webhook. If your source application supports adding multiple webhooks, you can clone your workflow, add the webhook from the cloned workflow to your source application, and set up the trigger step. You can then configure different filter conditions for each workflow.
Alternatively, if your source application does not support adding multiple webhooks, you can add a Router to your workflow and use a different filter condition for each route.
https://youtu.be/R4zxsQr70Dw?si=sRuHPwH9kERHMNiM
Just following up on this.
https://youtu.be/R4zxsQr70Dw?si=sRuHPwH9kERHMNiMs
