Is there a better way to Route >300?
Status: Closed · Asked by DarronW on · 0 views
Task History ID: IjU3NjUwNTZjMDYzNDA0MzM1MjZhNTUzNjUxM2E1MTY0NTQzNTBmMzEi_pc
What would be the best method if:
- provided I have , 132 different options per county(6);
- the 132 options are unique; based on the user's response gathered from the email parser
- will only generate only result ( conditional logic) - perfect
I am currently using 396 - routers because 2 of the counties share information.
Would there be an easier way to route the information, as i have made it as lean as I could?
At this point its working but only if pabbly can support that amount of routers but it will be meticulous.
Any assistance is appreciated
Your concern is being addressed here:
https://forum.pabbly.com/threads/router-limitations.25439/
