Loop not working
Status: Closed ยท Asked by Team Clothes Box Foundation on ยท 0 views
Thanks for reaching out.
When the Loop or Iterator node shows no array to select, it is usually because the response from the previous step is in Simple format, which breaks the array into individual comma-separated values and prevents the array from being detected.
Please try the following:
1. Open the trigger or action step directly before your Loop/Iterator step.
2. Turn off the Simple Response toggle (switch the Response Format to Advanced Response).
3. Click Save & Send Test Request to capture a fresh response containing the raw array data in square brackets [ ].
4. Open your Loop/Iterator step and select the newly captured array field under the Choose Array dropdown.
Also confirm that the path you are selecting actually resolves to an array. If it points to a JSON string instead, you will need to parse it first (for example with a Code step) before the Loop can read it.
Please check the screenshots shared and proceed accordingly.
