My connection is showing "Deposit items total must be equal to transaction total. (1900) (0)"
Benuser
Your Task History ID
IjU3NjUwNTZhMDYzMDA0MzI1MjY5NTUzNTUxM2Ei_pc
After creating an api connection, the result is showing "Deposit items total...." meanwhile everything is correct. Can you please help?
ArshilAhmad
Moderator
Hi @Benuser,
Since we don't have a direct integration with Bukku, we lack any information regarding the error you are encountering. The API documentation you have shared also doesn't provide much insight. We suggest you get in touch with the application's support team to gain a better understanding of the error.
