Need a better integration with Neto
shaw16
Hey there!
Glad to see that Pabbly Connect also has an integration with Neto. However, the trigger is weirdly only restricted to 'Order Status Changed'. Since the integration already exists, triggers in the 3rd screenshot would help in establishing Facebook Conversion API.
As an agency with clients having 200+ orders a day, Zapier is very expensive to maintain and Pabbly Connect may be a really good platform.
Hey @shaw16
As the integration on the platform is based on the Neto API documentation, we've thoroughly explored its functionalities. Unfortunately, we haven't come across any specific option to receive a webhook response when an order is paid.
Additionally, please verify with Neto if they send an order status of "New" along with the order information. If they do, you can use the same trigger event and set up a Filter action step to select the "Order OrderStatus."
