  • Please note that the team will not be available on 17th June 2024, due to a public holiday.
    During this period, support assistance may experience some delays.
need help with mapping value i tried to change with no success
alaa bebar
need help with mapping value i tried to change it with no success.
i correctly working on automation I need to map a numeric value.
here's a screenshot of the price written manually which gives a successful response when I send and save the request:
here is the mapping of the numeric value that is not working:
after I get a message missing a value, I close and reopen the route named "שכר טרחה מראש-רגיל" For the 9th router i have red bacon on the mapping value i tried varoius alterations to use, and change the column formatting and placement
Here is a screenshot after I reopened the router:
please help im trying to fix this damn mapping bug for a whole week
heres the workflow: https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZlMDYzZjA0MzY1MjY4NTUzNTUxMzUi_pc
alaa bebar
I tried that in the past, I'll record my attempt if I fail to execute the mapping part I'll share it with you.
did the team change something in the automation procedure or in the inn code of the mapping so I can learn if I did something incorrect?
@ArshilAhmad
ArshilAhmad
Moderator
You haven't done anything incorrect from your end. We just need you to capture a new response from Google Sheets in your workflow setup for testing purposes.
ArshilAhmad
Moderator
Our technical team is looking into the cause of this issue. I will get back to you as soon as I have any update.
alaa bebar
Hello Arshil, any updates on the mapping bug, I got a message from the technical support team that my ticket has been resolved.
Supreme
Regarding your concern can you please replace the double quotes with single ones' from your Google Sheets respective column and recapture your webhook response again from your workflow then refresh the workflow?
