rate limit de POST /api/v1/messages
Status: Closed · Asked by Andrea Lanari on · 0 views
Andrea Lanari — Question ·
En pabbly chatflow, ¿cuál es el rate limit de POST /api/v1/messages, se cuenta por token o por número, y en qué ventana?"
Pabbly Support — Reply ·
For the POST /api/v1/messages endpoint in Pabbly Chatflow, the rate limit is counted based on the number of messages/API requests, not per token.
  • When using Pabbly Chatflow through Pabbly Connect: The limit is 40 messages per second. This limit applies to Pabbly Connect as a whole and is not allocated separately to each individual customer.
  • When using the Pabbly Chatflow API directly, without Pabbly Connect: The limit is 10 messages per second.
Thanks and Regards,
Customer Success Associate,
Andrea Lanari — Reply ·
gracias
y si uso pabbly chatflow a traves de otro servicio externo a traves de api? En este caso el limite cuanto es?
Hey,
Thanks and Regards,
Perdona. no quisiera que se haya malentendido. me refiero a si se usa la api de pabbly desde otra plataforma, conectando esta plataforma tercera con la clave api de chatflow para que la plataforma envie la informacion y pabbly envie el mensaje. tambien en este caso el limite son 10 por segundo?
Hey Andrea,
Yes, if you use any external or third-party platform to make requests to the Pabbly Chatflow API, instead of using Pabbly Connect, the limit remains 10 requests per second.
However, please note that this limit applies to the overall customer base and is not a dedicated limit of 10 requests per second for each individual customer.
Thanks and Regards,
