Reddit Flow Is Failing
Jock
The flow that posts from our magazine to reddit is faililng consistently. Can support please help.
Supreme
Hey @Jock
Kindly share the task history id from your workflow in which you are getting failed Reddit action step.
Supreme
Hey @Jock
As we have checked your tasks history Id, we couldn't find any error in the data flow.
If you are having trouble getting the response from your trigger event then kindly recapture the webhook response once. Perhaps your webhook URL might not be intact in your triggering application.
Supreme
Hey @Jock
Kindly follow the given steps once to capture the webhook response from your "StoryChef" account.
- Login to your StoryCheif account
- Go to your relevant Workspace
- Navigate to the top right dropdown > Channels
- Click on Custom Website
- Click on Add New Destination button
- Copy the Webhook URL above & paste it under the webhook field.
- Save the Settings
Kindly try this at your end and then make a test submission by Publishing, Editing or Deleting a Story.
Supreme
Hey @Jock
As we can see from the video you didn't capture the webhook response at all, please capture the webhook response from your StoryChef account.
