Response not received in 15 seconds. Learn more: https://forum.pabbly.com/threads/pabbly-connect-timeout-limit-error-response-not-received-in-15-secon
Kenny
I have a workflow like this:
The woocommerce response is more than 15 seconds.
How to overcome this?
Supreme
Hey @Kenny
It seems like the application that you are using in the API by Pabbly was unable to process your request in under 15 seconds and because of that as a response you get the "Response not received in 15 seconds".
Perhaps you might be calling/using the application extensively or the data which you are passing couldn't process by the application itself.
Kenny
Hey @Kenny
Any workaround?
Supreme
Hey @Kenny
You can try a 1-Min delay before the action step in which you are getting the error.
Kindly give it a try and let us know if that works for you.
