Spacing Adjustments Clunky UX
Status: Closed · Asked by H Brown on · 0 views
H Brown — Question ·
If a layout, border or spacing default is "0" and you want to set it to 10, you either have to double-click to highlight the number or place your cursor and then backspace. If you highlight and delete or use backspace you then get "0" showing again. So you add "10" and it then shows "010" - which actually seems to work but it's very clunky.
It would be great if you could click once in these fields and it immediately highlights whatever number is there so you can simply overwrite.
Pabbly Support — Reply ·
Hello H Brown,
Thank you for reaching out and for sharing your detailed feedback regarding the input fields for layout, border, and spacing adjustments.
We understand that having the value automatically set to “0” or requiring multiple clicks to replace the existing value can make the design process inconvenient. Automatically selecting the input value on a single click and allowing it to be cleared easily would provide a smoother editing experience.
To help our product team review and prioritize the request, we recommend submitting it directly through our Pabbly Connect Roadmap:
You can add the details of the requested input-field behavior there, and our product team can review it accordingly.
Naman Bansod
Customer Support Specialist
🌐 Pabbly.com
👉 Rate your support
H Brown — Reply ·
Ok - I have added yet another request.
Hello H. Brown,
Thank you for reaching out to us again and for confirming that you have submitted your feature requests to our roadmap. We truly appreciate you taking the time to share your feedback and suggestions.
We understand your perspective regarding the requested design adjustments and workflow improvements, and how these changes could support your day-to-day operations.
Please note that once a feature request is submitted to our roadmap, our product and engineering teams review it based on factors such as technical feasibility, user demand, and development priorities across our platforms, whether it be any other tool or Pabbly Email Marketing itself.
While we are unable to commit to a specific implementation timeline, please be assured that your suggestions were recorded for the team's consideration. However, we tried to find your added feature requests but we were unable to find using registered Email Id.
It would be quite helpful for us if you could share the link to the feature request you have made so that we could share it explicitly with our concerned team, and if they provide any timeframe, we will share it with you
We genuinely value your feedback and continued association with Pabbly. We’ll be happy to help.
Shekh Dilshekh
🌐 Pabbly.com
🎉Black Friday Early Access
Signature image
Thank you for the prompt response.
As discussed, the team will review your request. Meanwhile, I've also shared the roadmap link internally so that the team can look into this matter as per their feasibility.
We appreciate your patience.
Shekh Dilshekh
🌐 Pabbly.com
Signature image
This is a quick follow-up to let you know that we are currently reviewing your request with the concerned team.
We have also shared the roadmap link internally so that the team can evaluate the requirement and consider it based on feasibility and scope.
We appreciate your patience and understanding while we look into this. We will keep you updated once we have further information.
Shekh Dilshekh
🌐 Pabbly.com
Signature image
Hello H. Brown,
We’re writing to share a quick update regarding the input text fields in the drag-and-drop email builder, specifically the spacing, border, and layout adjustments.
Our team has fixed the issue. You can now edit the input field values without the previous default value/highlight behavior.
Kindly try it in the email builder and let us know if everything is working as expected.
Shekh Dilshekh
🌐 Pabbly.com
🎉Black Friday Early AccessSignature image
H Brown — Reply ·
Amazing - that's great - thanks for the update! Do you know if they are working on the email template responsive behaviour (sections with 2+ columns need to stack and column gap needs to be respected as row gap when stacked)? That's the main thing stopping us from moving forward right now.
Hello H. Brown,
Thank you for confirming! We’re glad to hear the spacing and default value behavior is working smoothly now.
Regarding the responsive behavior of multi-column sections, could you please share a screenshot of the specific layout that is currently preventing you from moving forward?
Once received, we’ll share the details with our team and assist accordingly.
Shekh Dilshekh
🌐 Pabbly.com
We have checked and confirmed that your concern has already been escalated to the concerned team, and they are currently working on it. You also previously discussed this matter with our relevant team member, who informed you about the same on a different thread.
We kindly request you to allow us some time. Once we receive an update from the concerned team, they will reach out and assist you accordingly.
Regarding your initial concern, we have confirmed that the issue has been fixed. For any further follow-up on that matter, we request you to continue the conversation on the same forum thread you recently shared.
https://forum.pabbly.com/threads/responsive-settings-for-mobile.220266
For now, we will be closing this specific ticket.
Shekh Dilshekh
🌐 Pabbly.com
H Brown — Reply ·
Will do. Thanks.
