Stripe automation - need tax functions created
twshouston
@Supreme Verma
Ok new question for you today. I'm testing out some new workflows and would like to see if the team could add the tax fields into the stripe automation.
Currently the stripe automation works very well my only challenge is that I would like to have the stripe automated tax field available.
Basically the workflow is
Step 1> to create and item and assign it a tax class and put it in the stripe invoice item queue.
Step 2> Create an invoice with auto tax enabled which will adjust the taxes automatically ( on the stripe side) when the customer pays.
{Stripe: create an invoice module}
Automatic Tax Enabled
{Stripe: create and invoice item}
If you need more information please let me know.
Thanks a bunch.
twshouston
Thanks it should be similar to the initial setups available.
I was considering using the API but I though someone might have the same challenge and it's best to reach out 👍
Hey @twshouston
We have made the changes in the new action event of the "Create an Invoice" Action event accordingly and made the previously used action event legacy.
Kindly use the action event in the automation and let us know how it is working.
