Tags in FB lead
Supreme
Hey @Trinity One Social
You can simply pass the Tag Id in the "Tag Id" field of the "ActiveCampaign: Create or Update Contact" If the desired Tag is already available in your Active Campaign then you can retrieve it with the help of "ActiveCampaign: Search Tag" or you can create one with "ActiveCampaign: Create a Tag" action event.
So, we need to first search whether the tag is already created or not. Then we can set the router action step according to the existing tags.
So the following two cases will be there -
Case 1 - Tag ID Already Exists >> Create or Update Contact
Case 2 - Tag ID Does Not Exists >>Create Tag>> Create or Update Contact
After getting the Tag Id from either of the action events you can map the Tag ID as mentioned in the following screenshot.
