Waiting for Webhook Response
I setup a trigger based on a Jotform response. I clicked on the Capture webhook response, and it worked great. I then realized I would have challenges with my data and so amended the Jotform, and then clicked on Re-Capture webhook Response. I've done this over a few days. It spins, and no response, and the response data received in the data table is the old data/form fields. How can I get this 'recapture' to work? I did go into Jotform and repasted the webhook just in case that would work, but it did not.
Fagun Shah
You need to submit the form once again when you click on Re-capture the Webhook Response.
So it the jot form will send data in new format to pabbly connect again.
