We tried to assign the values in the spreadsheet and the pabbly keep populating the data in wrong cells
Status: Closed Β· Asked by Ashok G on Β· 0 views
Ashok G β€” Question Β·
Dear team,
We tried to populate the facebook form data to Google spreadsheet. but every attempt the data keep populatong in a non-designated cell. We refresh the sheet, refresh the flow, refresh step. We done everything to fix it but no use.
Note: The previous intereference was good, the current intereference is more inconvinient to work.
Pabbly Support β€” Reply Β·
Hi Ashok,
Thank you for contacting Pabbly Support.
To help us investigate why data is populating into the wrong cells of your spreadsheet, could you please grant us editing access to your Google Sheet and share the Google Sheet link with us?
Access is required for naman.bansod@pabbly.com & support@pabbly.com.
Once you provide the Google Sheet link with editing access, we will inspect your workflow WC-TKG-220926-OTP-V1(35L).
Looking forward to your reply!
Naman Bansod
Customer Support Specialist
🌐 Pabbly.com
πŸ‘‰ Rate your support
Ashok G β€” Reply Β·
We shared the access.
We are populating the data to Meta-2 Page
Hi Ashok,
Thank you for providing editing access to the sheet!
To help us pinpoint and fix the exact cell mapping issue as quickly as possible, could you please email us at support@pabbly.com with the following details?
  • Affected Row & Column/Field: Which specific field or column in the Meta-2 sheet is receiving incorrect data?
  • Incorrect vs. Expected Data: What value is currently populating in that cell, and what data should ideally be there instead?
  • Sample Instance: A quick screenshot or row number showing an example where this occurred.
Once you share these details with us via email, we will investigate further.
Naman Bansod
🌐 Pabbly.com
We need to assign the data for Camapign Name, Adset name and Ad name on Campaign, Ad Set and Ads coloumns Repectively
Hi Ashok,
Thank you for clarifying.
Naman Bansod
🌐 Pabbly.com
Just following up on our previous email to help us pinpoint and fix the exact cell mapping issue as quickly as possible, could you please email us at support@pabbly.com with the following details?
Naman Bansod
🌐 Pabbly.com
Hello!
It seems that the matter has been resolved, as we haven’t received any further queries from your side.
If there are any other concerns, please do let us know. We will be happy to assist you.
Naman Bansod
🌐 Pabbly.com
Back to all forum threads Β· Log in to reply
