Same BigCommerce Order Trigger Creating 3 Separate Pabbly Executions
Status: Closed · Asked by Allan Hoffmann on · 0 views
We have an active BigCommerce → Saasu workflow in Pabbly Connect called “BC Order To Saasu 1:2 - ACTIVE”.
A single BigCommerce order is resulting in three separate Pabbly task executions, which consequently creates the same Sales Order three times in Saasu.
We have confirmed that there is only one BigCommerce webhook configured for this workflow.
This has also occurred on other orders, so it is reproducible and is not isolated to a single order
Could you please inspect the inbound webhook/execution logs for these three execution IDs and confirm:
Did Pabbly receive three separate HTTP webhook requests from BigCommerce, or did Pabbly receive one request and create three executions from it?
If three requests were received, could you please provide the relevant request timestamps/identifiers so that we can investigate the BigCommerce side.
If only one request was received, please investigate why Pabbly generated three separate workflow executions from that single trigger.
We have already established that the duplication occurs at the workflow execution/trigger stage, before the subsequent Saasu actions are performed.
Thank you.
Hello Allan,
Thank you for sharing the information.
To investigate this further, please share the Task IDs or Execution IDs for the three duplicate executions with us at support@pabbly.com.
It would also be helpful if you could share a screenshot or screen recording showing the data that was received three times for the same BigCommerce order.
With these details, our technical team will be able to check the webhook and execution logs from our end and identify the exact cause of the duplicate executions.
Once we receive the required details, we’ll investigate this further and assist you accordingly.
Allan Hoffmann:
We have an active BigCommerce → Saasu workflow in Pabbly Connect called “BC Order To Saasu 1:2 - ACTIVE”. A single BigCommerce order is resulting in three separate Pabbly task executions, which consequently creates the same Sales Order three times in Saasu. We have confirmed that there is only one B
IjU3NjYwNTZmMDYzMjA0M2M1MjY1NTUzNjUxMzE1MTZhNTQzMjBmMzAi_pc
IjU3NjYwNTZmMDYzMjA0M2M1MjY1NTUzNjUxMzE1MTZhNTQzMTBmMzki_pc
IjU3NjYwNTZmMDYzMjA0M2M1MjY1NTUzNjUxMzE1MTZhNTQzMjBmMzIi_pc
Hi Allan,
We’ve escalated your query to our technical team for further investigation. They are currently looking into the issue, and we’ll get back to you with an update as soon as we have further information.
Thank you for your patience and understanding.
Hi Allan,
Since the duplicate executions are still being investigated and resolving the issue may take some time, we recommend using the following workaround for now:
Clone the existing workflow “BC Order To Saasu 1:2 - ACTIVE”.
In the cloned workflow, re-establish the BigCommerce connection and proceed with the setup.
Once the cloned workflow is ready and working correctly, make the current workflow inactive to avoid duplicate entries.
While setting up the BigCommerce trigger, use “Save & Send Test Request” only once, when establishing the connection.
For capturing/test data afterward, please use “Recapture Webhook Response” instead of repeatedly using “Save & Send Test Request.”
This should help you continue working while our technical team investigates the duplicate execution issue.
If you face any difficulty while cloning or reconnecting the workflow, please let us know.
Hi Allan,
Just following up on our previous email regarding the duplicate execution issue.
We hope you were able to set up the cloned workflow using the suggested workaround. Please let us know if you need any assistance with the setup or if you are still facing the duplicate execution issue.
Yes the cloned workflow is working well - thank you
Hello Allan,
Thank you for the confirmation. We’re glad to know that the cloned workflow is working well.
Since the issue has been resolved, we’ll be closing this support request.
If you need any further assistance in the future, please feel free to contact us at support@pabbly.com.
We would also greatly appreciate it if you could share your feedback on your support experience using the following link: https://bit.ly/3V2Pjia
