Assinafy OAuth PKCE integration — technical review before publication
Status: Closed · Asked by Bill Madeira on · 0 views
Hello Bill,
Thank you for reaching out and for the detailed questions regarding your Assinafy integration.
Please be informed that we have shared the issue with our Integration Team for further review, and our team is looking into it. We will get back to you with an update as soon as we receive further information from the team.
We appreciate your patience and understanding.
Shekh Dilshekh
Customer Support Specialist
🎉Black Friday Early Access
Thanks for sharing the detailed questions. Please find our responses below:
State & Issuer Validation
Pabbly’s native OAuth flow supportsstatevalidation. However, validation of the authorization-responseissparameter against the configured issuer is not currently supported.Refresh Tokens
Please enable “Refresh access token on expiration” in the OAuth settings for the Assinafy integration. This will allow Pabbly to refresh the access token when it expires.Expired Authorization Code / Revoked Connection
Both scenarios can be tested manually:For an expired authorization code, use a code that has exceeded Assinafy’s 60-second validity period and initiate the authorization flow.
For a revoked connection, revoke the connection and then run the workflow again to verify the resulting behavior.
429 Responses / Transport Timeouts
Requests are not automatically retried within the same workflow run. For write operations, we recommend implementing an appropriate mechanism on the application/API side to prevent duplicate operations when a transport timeout occurs and the outcome of the request is unknown.Custom API Request – Allowed Domains
The allowed domains for the Custom API Request are taken from the API URLs configured for the application. If the UI shows Allowed domains: [none], it means that no domain is currently allowed. For the initial release, the Custom API Request feature can remain disabled.Publication & Review Process
The current publication flow is:
Developer Portal → App Status → Submit for Review.For the review, please provide a dedicated test account that the reviewers can use to validate the integration. Please avoid sharing production credentials or account access.
We hope this clarifies the supported behavior and verification procedures. App-specific details can be provided through the appropriate private/secure channel if required.
Best regards,
Shambhavi Pandey
Pabbly Integration Team
