Arshita, I think you guys have this features, Stuff Member Supreme created the flow something similer to this what I said in my first conversation, n you can in between out of blue to say you don't have this feature, anyway... but I want you to have a look at this, it's clearly shows that you are not even reading previous conversation, then simply don't ans it when you cannot do the research, I simply asked for clearity what flow I was given similer to what I said by supreme stuff member, which you claim (Arshita) Claim to not have this features, Then what should I do. I feel you have this fearure,
Can you guys check this flow first rather than shwoing the behaviour getting rid of me. why I felt bad as my question and doubt were not answer rather simple line. Arshita you better not handle this, I know you don't have time read or see. Plzzz can I have Supreme, Truly HE or She is Supreme, Understand and reply, Supreme gave me this flow demo which is similer to what I want here below
Automate your sales and marketing with Pabbly. Unite email marketing, lead capture, WordPress themes, subscription all at one place.
connect.pabbly.com
And I asked this upon getting this flow... Below
Thank you for this demo Flow, but Condtion in router is sub of clearity in first router in demo flow named as
08 to 23:49, it give command as Greater than 7 & less than 23, It means between morning 8AM to 11PM msg will be fired, Question is What time it will go between this time frame. What I have understood that there is delay for 24 Hrs, it will send msg In next 24 Hrs only if it will fall into this time frame 8AM - 11PM, Right? So let me take a random scenario 1 AM-- Now Flow Action is --- Instant Msg Sent -- 24 Hrs Delay (However it will be next day 1 AM msg will be on hold until 08 AM Morring) --- Msg Sent(08 AM Now like wise this user will get other 2 msg same Time) Right?
Other Router Named as 00 to 08, so much confusing there is time date formatter is user justed after filter in above I mentioned not used, seems it send msg only In Night (Which is don't need if this is for that),
I have set up until router as it is and so far instant msg result is achived, bit confused.
Almost I got the idea and set it up, not sure if this the one I exactly need. So Below Again Mentionating the result want to achieve.
After Instant Msg (Which is really easy to set up) I want to sent other 3 Notification Making sure msg must not go Between 08 AM to 8PM Every Day, That's all.
And I am loving your product very much Sooner I will 50k/M, just be with me I am highly confident that we will handle all obstacle, Thanks for your demo it helpmed me but failed to set up, Hope you will understand the gap and fill it as usual.
I would not doing this reverse Engg, if I had strait fwd Ans.
