Asana Create a Task Not working as intended
Your Task History ID
IjU3NjUwNTZlMDYzMjA0MzA1MjZiNTUzNzUxMzAi_pc
I have the exact issue described by member @lifeinjamisty when creating an Asana Workflow. I am not sure how member @lifeinjamisty resolved this issue.
I have been able to get most workflow steps to work correctly apart from Create a Task. I have tried various ID variables but I keep getting the same error msg. Projects. Not an array. Yet, I can pass the same variable in the step before and after and create a Section in the project successfully?
I have added the [" variable id ]" but I still get the same partial error. Been trying to resolve this for the past few hours with no luck. Not sure if you can provide some guidance as to what I am doing wrong.
Kind Regards
Patrick Hall
Hey @Patrick.Hall
We have already replied to your query on your another thread, please check that out.
