Assistance Required to Connect Custom Slack Bot with Pabbly Connect
Status: Closed · Asked by Ojasv Quickship on · 0 views
Ojasv Quickship — Question ·
Dear Pabbly Support Team,
I have created a custom Slack app named Q-Buddy for our billing automation and generated its Bot User OAuth Token (xoxb-).
However, while creating a Slack connection in Pabbly, I am only redirected to authorize the Pabbly Connect Slack app. I am unable to find any option to enter the Q-Buddy bot token. I also searched for API by Pabbly, but the option is not available in my account.
Our requirement is to send channel and direct messages through our custom Slack app Q-Buddy, using its name and icon.
Please guide us on how to connect the custom Slack bot token with Pabbly Connect. Screenshots are attached for reference.
Ojasv
QuickShip Global Express
Pabbly Support — Reply ·
Hello Ojasv,
Thank you for reaching out to us.
Kindly refer to this video tutorial to learn how you can connect Slack as a user or a bot in Pabbly Connect -https://youtu.be/weAtQOmsgwA?t=454
Further, the API by Pabbly is now API (Pabbly) in Pabbly Connect.
Adeel Akhtar
🌐 Pabbly.com
Ojasv Quickship — Reply ·
NO Such App, i cant spot any
and i want to add a Slack App as an action in my flow, so where shall i paste the token and Id fro slack, as we did it in developer.facebook for whatsapp (Meta)
Hello Ojasv,
Further, API (Pabbly) can be set up only as an action, so try searching with just the term API, and you will see it.
Adeel Akhtar
🌐 Pabbly.com
