Automation from Formaloo to Pabbly Generates Double Input
lenovoman
Dear Pabbly Connect Team,
I am wondering why this execute 2 times? Same date and time. So, I got 2 results in my Google Sheet instead of 1 result. It should be one result because I only entered once.
This happens several times.
Please help and check if there's bug in here.
Thank you.
Sincerely,
Henry Iriawan
Supreme
Hey @lenovoman
As we can understand from your concern, you might have configured the webhook URL of your trigger event twice on your Formaloo account and because of that, you might be getting the same data twice from the application.
Since the trigger event is a webhook-based trigger that only gets the data from the application once send by the application itself.
So, kindly cross-check in your Formaloo account that is there any webhook URL that gets established twice.
lenovoman
Thank you for your information.
Per today, I tried again and nothing triggers twice. For Formaloo itself, it contains only once data. The thing that I found is in pabbly connect because it triggers twice for one data. But for now, it is already fixed.
Thank you
