BUG "Fields are required"
Status: Closed · Asked by Influencers Agency on · 0 views
I’m having an issue with the WhatsApp step in Pabbly Connect. It shows the error “Fields are required” even though all required fields are filled and mapped correctly.
At first, I thought Pabbly was using an old webhook response, so I created a completely new form and captured a new webhook response from scratch. This new webhook has only one response, so there are no old responses that could be causing a mapping conflict.
However, the same error still occurs. All WhatsApp template fields have values, but Pabbly still says that required fields are missing.
Could you please check why Pabbly is detecting empty/required fields when all the fields are populated?
The issue happens when I clone routes. After cloning a route, I cannot save any WhatsApp number because Pabbly keeps showing the “Fields are required” error, even though all required fields are filled in correctly.
Thank you for bringing this to our attention.
We've reviewed the issue and have escalated it to our technical team for further investigation.
Our team will look into the issue, and we'll keep you updated as soon as we receive any information from them.
We appreciate your patience in the meantime.
Thanks & Regards,Anushka Sahu
🌐 Pabbly.com
Hello!
The issue you were facing has now been resolved. We request you to please check it from your end and confirm whether everything is working as expected.
If the issue still persists, please let us know, and we’ll investigate it further from our end and assist you accordingly.
Soumya Tripathi
Customer Support Lead
🌐 Pabbly.com
