Converging two streams?
After using Pabbly Router to make as decision is it possible to bring the 2 streams back together? ie. when a customer is added to a JotForm, router says... if this customer is not already found in QBO then add them. If they are found, then update the phone/address with the data entered. AFTER that process, both streams need to have various invoices created, and other actions. I would like to have these streams come back into one stream rather than having 2 parallel streams doing the same thing.. is this possible? See flowchart below for how I'd like to see 2 streams come back together.
  • pabbly converge.pdf
Fagun Shah
Not possible inside a single workflow bcoz Router is the last step of the workflow.
But there are easy workarounds available -
1. You can add Create Invoice1, Create Invoice 2 and Send AppInvite steps to both the routers. You can basically clone the route.
2. Send data to another workflow and handle the rest of the steps there. Check this video on how to do that - https://www.facebook.com/groups/formget.deals/posts/1026010181511937/
