D7 Number Verifier
D7 Number verifier Integration with Pabbly Connect:
This documentation provides a detailed, step-by-step guide for integrating your D7 account with Pabbly Connect. Following these instructions will enable you to establish a seamless connection between the two platforms.
Integration Steps:
1. Choose "D7 Number verifier" in the action step:
  • Within Pabbly Connect, navigate to the action step and choose "D7 Number Verifier" as the action you wish to perform. Select an action event, such as "Number Lookup".
2. Configure the Connection:
  • To establish a connection, select "Add New Connection" and enter the API token by following the steps. If you already have an existing connection, you can opt for "Select Existing Connection" instead.
Actions:
1. "Number Lookup"
  • Use Case: To retrieve details about a specific phone number.
  • Select the "Number Lookup" action, connect your D7 account, enter the phone number with the country code, and click "Save and send test request."
Upon completing the above steps, your D7 account will now be successfully integrated with Pabbly Connect. You can utilize action to get the details of any specific number. With this integration, you can automate processes through Pabbly Connect, improving your workflow and enhancing your productivity. If you encounter any issues or require further assistance, feel free to reach out to our support team for help.
