Fix error (#100) The parameter messaging_product
MFodaTech
Hello There,
I wish all the happiness to the technical team.
WhatsApp message not arriving through pabbly due to parameter messaging_product
Here are screenshots from your website
Greetings and respect to you,
Monzer Foda
Hey @MFodaTech
Can you please record a short video once, so that we can look into it and help you accordingly?
You may refer to the following video lesson to get an idea of configuring the webhook URL in WhatsApp Cloud API.
Hey @MFodaTech
Instead of using API by Pabbly to send the WhatsApp messages kindly try using the dedicated integration to do the same.
When you send another WhatsApp message using the action step, the trigger will initiate the workflow again because you've selected the trigger for any received message, creating a loop.
MFodaTech
@Supreme
Good morning
The test was completed successfully.
Look at the video!
But how do you send to a number of recipients via Google Sheet or a text file?
Regards,,,
  • Video_2024-04-17_082208.mp4
    1.9 MB
Hey @MFodaTech
You can refer to the following video lesson if you want to respond to the recipient based on the incoming message or with specific content.
