Flow Builder/interface.
Status: Closed · Asked by Rolando Segovia on · 0 views
Rolando Segovia — Question ·
Hi! I have a question regarding the new Flow Builder/interface.
Until now, I’ve been using the classic flow builder, and I’ve noticed that the interface has now changed quite a lot, with the new visual/diagram-style approach, similar to tools like n8n.
I’m currently managing a large number of flows related to campaigns, APIs, webhooks, automations, etc., so I’m a little concerned about the migration.
Could you please clarify:
  • Will my existing flows continue to work as they are?
  • Is there any plan to provide support or assistance for migrating existing flows to the new system?
  • Will there be an import/export system that allows us to automatically convert or migrate the existing flows to the new format?
  • Or will we eventually have to rebuild all our existing flows manually?
I have quite a lot of complex flows running, and honestly, I don’t have the time to recreate everything from scratch.
I’d really appreciate it if you could clarify how Pabbly is planning to handle this transition and what options will be available for existing users.
Thank you!
Pabbly Support — Reply ·
Hello Rolando,
Thanks for contacting us.
We are moving forward with the retirement of the Classic Builder in Pabbly Connect.
Here are the key updates:
  • Users can no longer create new workflows from the Classic Builder. New workflows can now be created only in the New Builder.
  • All new features, improvements, and updates are being released only in the New Builder.
  • We are planning to migrate all existing workflows from the Classic Builder to the New Builder. Users don't have to take any action at the moment to migrate the workflows. The workflows created in Classic Builder are not going to disappear or be removed.
  • We are not adding any new features or updates to the Classic Builder.
  • The Classic Builder will be completely retired in the future.
Adeel Akhtar
🌐 Pabbly.com
