How add more emails for alert messages?
Status: Closed · Asked by pycoder on · 0 views
pycoder — Question ·
I am writing to inform you that I currently have an account registered with the email address [[email hidden]], however, I do not check this inbox on a daily basis. As such, I would like to request the addition of another email address, [[email hidden]], to receive alerts in the event that a task is automatically or manually disabled.
I believe that this update will improve our communication and ensure that any potential issues are promptly addressed. Thank you for your attention to this matter.
Best regards, Pabbly user
Hey @pycoder
You can use the Pabbly Connect Manager feature on the workflow which will notify you of the trigger event of workflow failure and send you a mail/WhatsApp notification accordingly.
For a better understanding, you can check the following video tutorial.
youtube.com/watch?v=Kl1iy26wxZY
pycoder — Reply ·
Hey @pycoder
Thanks, @Supreme for your reply.
Your solution is working, but this is not free. I will need to pay extra for this.
