How Can I Automate WordPress Website Leads Using Pabbly Connect?
Status: Closed · Asked by Rockzen construction on · 0 views
Rockzen construction — Question ·
Hello Pabbly Community,
I manage Rockzen USA INC, a construction company serving New York City. Our website receives inquiries for services such as sidewalk repair, concrete construction, and basement waterproofing.
I want to streamline our lead management process using Pabbly Connect. Ideally, whenever a visitor submits a contact or estimate request form on our WordPress website, their details should automatically be added to Google Sheets and an email notification should be sent to our team.
I would also like to know whether Pabbly can help organize inquiries by service type and trigger follow-up emails without creating duplicate records.
Which triggers and actions would you recommend for this workflow? Is there a reliable way to handle failed submissions and prevent duplicate leads?
Website: https://rockzenconstruction.com/
Thank you for your guidance.
Pabbly Support — Reply ·
You can use Pabbly Connect to automate your lead management process by capturing inquiries submitted through your WordPress website, adding them to Google Sheets, and sending email notifications to your team.
Please refer to the following video tutorials for guidance:
  1. https://youtu.be/1382gOVKhdU
  2. https://youtu.be/AAnPryVKngs
You can follow the steps below to set up your workflow:
Step 1: Capture WordPress Form Submissions
  • Log in to your Pabbly Connect account and create a new workflow.
  • Select the appropriate trigger for your WordPress form plugin. If a suitable trigger is unavailable, use Webhook by Pabbly to capture form submission data.
  • Submit a test inquiry through your website to capture the form fields in Pabbly Connect.
Step 2: Check for Existing Leads Using Lookup
  • Add Google Sheets as the next action application.
  • Select the Lookup Spreadsheet Rows action event.
  • Connect your Google account and select the spreadsheet and worksheet where your leads are stored.
  • Configure the lookup using a unique identifier, such as the form submission ID or another reliable identifier, to check whether the lead already exists.
  • If the lead already exists, prevent the workflow from adding a duplicate record. If no matching record is found, proceed with the next steps.
Step 3: Add Lead Details to Google Sheets
  • Select the Add New Row action event.
  • Connect your Google account and select the spreadsheet and worksheet where you want to store the leads.
  • Map the form fields, such as name, email address, phone number, service type, and submission date, to the corresponding columns in Google Sheets.
Step 4: Send Email Notifications
  • Add Gmail or Email by Pabbly as the next action application.
  • Configure the recipient email address, subject, and message body.
  • Map the relevant lead details into the email so your team can review each new inquiry.
Step 5: Organize Leads by Service Type
  • Include a service type field in your WordPress form, with options such as sidewalk repair, concrete construction, and basement waterproofing.
  • Use filters or routers in Pabbly Connect to direct inquiries according to their service type.
  • If required, configure different email notifications or follow-up messages for each service category.
Step 6: Handle Failed Tasks
  • Open your workflow's Task History in Pabbly Connect to review failed executions.
  • Check the error message, correct any connection, mapping, or application issues, and re-execute the failed task when appropriate.
  • Test the workflow with sample submissions before enabling it for regular use.
Once configured, this workflow can help you centralize incoming leads, notify your team promptly, and organize inquiries for follow-up.
The exact trigger setup will depend on the WordPress form plugin you are using, such as WPForms, Contact Form 7, or Elementor Forms.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
Black Friday Early Access
Just following up on our previous email to check if you need any further assistance from our end.
Please feel free to let us know if you have any questions or concerns. We’ll be happy to assist you.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
We’re following up on our previous email regarding your query. As we haven’t received a response, this will be our last follow-up, and the ticket will be closed automatically.
If you still need assistance, you can email us again at support@pabbly.com to raise your concern.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
