WATI templates not loading in Pabbly Connect
Status: Closed · Asked by Dr.Mayank Dave on · 0 views
Dr.Mayank Dave — Question ·
Hello Pabbly Support,
I am setting up a workflow named “Razorpay Payment to Wati”. The goal is to send an approved WATI WhatsApp template after a Razorpay payment is captured.
The templates are approved and visible in my WATI account. In Pabbly, the WATI connection shows “Connected”. I created a WATI API token with the scopes messagetemplate:read and messagetemplate:write, and entered the WATI API Endpoint and generated token in the Pabbly connection fields.
However:
1. In WATI – Get Message Templates, the test response is {"response":""} (Page Size 10, Page Number 1, Raw format).
2. In WATI – Send Template Message, the Template dropdown shows “No Options Found”, even after refreshing the fields and the template dropdown.
3. I also tried both Send Template Message and Send Template Message (Legacy).
Could you please check why Pabbly is not fetching my approved WATI templates and advise how to fix the connection?
I have attached screenshots of the approved templates and Pabbly’s blank response and dropdown. I have not included the API token.
Pabbly Support — Reply ·
Hello Dr. Mayank,
Thanks for reaching out and for the detailed description. When WATI templates are approved and visible on the WATI side but Pabbly Connect returns a blank response and shows "No Options Found" in the Template dropdown, it is almost always caused by a stale or expired WATI access token on the saved connection. Even if the connection shows "Connected", an expired or rotated token can silently fail to fetch templates.
Please try the following:
1. Log in to your WATI account and generate a brand new access token. Do not reuse the existing one, even if it looks valid - an expired or rotated token will silently fail.
2. In Pabbly Connect, open the WATI action step, click the connection dropdown and choose Add New Connection (re-establish it fresh rather than only editing the old one).
3. Paste the new WATI API endpoint and the newly generated token, then save. Confirm the connection's updated timestamp actually changes - if it still shows the old date, the save did not take and you should re-enter and save again.
4. Click the refresh icon on the far right of the Template dropdown to re-pull your approved templates.
5. Re-test the Get Message Templates and Send Template Message steps.
A few additional checks if templates still do not appear:
- Make sure the templates are in Approved status on the WATI side (pending or rejected templates are not fetched).
- If you have multiple WATI connections (e.g. WATI, WATI 2), confirm you are updating the correct one.
- Try re-selecting the connection in the action step after refreshing.
If the issue persists after re-establishing the connection with a fresh token, please let us know.
Adeel Akhtar
🌐 Pabbly.com
Signature image
