I'm finding it hard to use Pabbly for anything because it uses webhooks for literally everything.
Example - I can't use Twilio with Pabbly because the webhook slot is already being used by other platforms (HighLevel, Jensen.ai) to configure the phone number in the first place. If I remove that then I can't configure whisper messages, call routing etc.
How can I set up automations for Twilio if the only option is to use a webhook but I can't replace the webhook the Twilio phone number already has?
