how many posts does iterator process
Status: Closed · Asked by serwar habib on · 0 views
Hi Serwar,
Thanks for reaching out. When an Iterator stops partway through (in your case after 12 of 100 rows), it's usually related to how the Iterator queues and processes entries rather than the Iterator giving up.
Here are a few things to check and try:
1. Add a Delay After Queue step right after your Iterator. The Iterator can fail, time out, or stop short on larger runs, and adding a Delay After Queue step queues the responses so each iteration is processed sequentially. To do this:
- Open the affected workflow.
- After your Iterator step, add a Delay After Queue action step.
- Configure the delay (even a short delay is enough to enqueue items).
- Save and re-run the workflow.
2. Confirm the source step is actually returning all 100 rows. If the rows come from a Google Sheets Lookup step, make sure your Search Column/Search Value criteria match all the rows you expect, and that the correct sheet and tab are selected. If the lookup only returns fewer rows, the Iterator will only process that many.
3. Keep in mind the Iterator has size limits per run (up to 1000 array elements per level), so 100 rows is well within range once the queueing is handled.
If the issue persists after adding the Delay After Queue step, please share your Task History ID and Google Sheet, and grant access to aditya.chourey@pabbly.com and support@pabbly.com so we can investigate the specific run further.
If you prefer to keep these details private, you can send them directly to support@pabbly.com, and we will continue the conversation there.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
Black Friday Early Access
Just following up on our previous email to check if you need any further assistance from our end.
Please feel free to let us know if you have any questions or concerns. We’ll be happy to assist you.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
We noticed that we haven’t received a response regarding your query.
As there has been no update, we are closing this support ticket for now. If you still need assistance, please feel free to open a new ticket, and we’ll be happy to help.
Aditya Chourey
🌐 Pabbly.com
👉 Rate your support
