How to connect Pabbly Email Marketing to Zapier?
You can connect PEM to Zapier to perform fulfill various use cases:
  1. You can import your subscribers from x source to Pabbly Email marketing automatically by integrating it via Zapier or Pabbly connect
For Example:
  1. If a payment is made in Instamojo, the subscriber has to added in Pabbly email marketing (In a specific list)
Step: 1 Login to zapier https://zapier.com/
Step: 2 Go to create Zap
Y5DuRSds7F3dNJcqJ7MnMcfDEhSgNezpasDQoYwdw6Ub8kw2qqvDwDpmAUyMRvq5nC3z-SDc7Q1wbBkYLpXNHS-W1gAWQ3AOqrpazNNJXJRFp2Weo9DB3TkDMmHrWUuD1QbGCVExt4zK3Nh1Ls0V_-8ZegJJqOX5vErfrwvBeIsfhv5aGWdbU4z3eNQ1oA
Step: 3 Give a trigger as per your preference, link your account, and click on continue.
oZ5LQi5ETUAX8kVLQXqcHWbNF0TYgssnW0Fet5vHBueMJolcYyUSgRyN_XhKOGYZNKUPydW635OpYADayhOgndTE_OpAmFs0HtPx0kEGpnsZc0-DvbwxVVGJEwjKe1wQ_75Ary9Rli55VSDkl9_nv998gNlZ84Plq9Lyt3cRIcTE7FPKCkZjUGqf0Y5JPg
Step: 4 In action select the app event as webhook by Zapier, select custom request an event, and click on continue.
2Sg4UHuPUwUy11LwvXX8HYOGSdRfiJljvCyKy4RPjb6P90pTMXo7_d-dFx0vjGduFJR_FRXxswFxMAN8bG2JbbGfFbWTJEv-p0dFDR36-eqy5WsOue2S71ac7Tt6KDtr7ZvN0vLvgu-Nsin1hJuavfoZWpUGLQvnXbMEEL6_Uz5nVAaNka74HlUAV5G9uQ
Step: 5 In set up the action, choose post in the method —----------->
  1. Add https://emails.pabbly.com/api/subscribers in the URL —------------->
  2. In the data add the field in the basic Jason format
"import": "single",
"list_id": "Ijg1MDM***CI_3D",
"email": "[email protected]",
"name": "Ronie",
"city": "New York",
"date": "2020-02-21 00:51:25"
***Now here map of the list id as per the LIST in PEM, in which you wish to push the data.
***And map the name/email and all the other custom fields as per the data you are getting from Instamojo.
***Please make sure the last entry i.e. date in the above case will not have a comma (,)
r2CyhAC66oHEAI8cUY2oL1t0a-61h0w3csj2LY3y4KuWPaOj9zV9CG12eSk90oJps5OLFtWULJTGnO3aw_HQ_VoXi5o9YwRzmEJvVxrMpeHdDEYA-T5XWq_NcNKIgjaFk766driJBGZXIkduxto1bsA7ZOxENi5xJEdHhk3T05r9RlFBQgSe0o-ohoS6XA
Step: 5 In the header write Authorization and enter the text Bearer (and add the bearer token from PEM)
Step: 6 Click on continue!
