How to Execute Once and Stop Infinite Loop?
david
I want to run the loop once and stop infinite loop. How can I do it?
david
My limits are exhausted I need to wait for support to refresh because I could test and fix it. Seems like there is no easy way to stop a infinite loop that updates the same row of records in Workiom
Pabbly
Administrator
We have reset the task. Please check at your end.
Pabbly
Administrator
Please help me reset again.
Is there any suggestion to stop a infinite loop when updating the same record?
We have reset the task. You can create two separate workflows which will resolve your loop issue permanently-
Workflow 1 - Workiom to Browser Bird to Google Sheets
Workflow 2 - Google Sheets to Workiom
david
This makes me consumes more tasks and is an extra workflow. Any other alternative?
david
@Pabbly I just check my history of tasks and discovered that the webhook was triggered 8 times for a single "record update" event. Can we islolate the issue if it's from Pabbly Connect or Workiom?
