Integration with Tawk.to
Sketra
I need a guidance regarding integrate Tawk with Google Sheet.
The webhook currently work only with Chat Starts, End or New Ticket. ( Those work done)
I need how can I capture Offline Message response tawk. I try to capture but capture not done. Kindly help regarding the same.
Supreme
Hey @Sketra
Regarding your concern on Offline Form Submission, you need to contact their support team. As they haven't mentioned anything related to the webhook trigger which you are looking for.
Sketra
and we also need help regarding fetching the details from Servtel using their webbook. If you can help us with that also or with meeting kindly let us know.
Supreme
Hey @Sketra
Is there any support for JS API in your Pabbly to fetch the details?
Currently, JS is not supported on the platform, we can only support Rest API.
You can try Webhook By Pabbly, if they provide a Webhook URL then you can copy the webhook URL and add it under the webhook section of the Servetel. Once you're done with adding the webhook URL, then do a test submission/record in that application in order to capture the webhook response here.
Tutorial Video -
