Iterator - Problem in setup
Hi!
I try to split a long string into pieces, but the iterator does not show the data from the back level.
I try from webhook and from the mail. but this not working, it shows nothing.
Fagun Shah
Did you captured the data with Simple Response toggle turned off?
Only then it will capture data in array format which you can use in Iterator step.
Thanks!!
I understand. if a simple response turns off it shows fields with [ in start and ] in end.
I can add [] to other fields?
Fagun Shah
Other fields are not in arrayformat, that is why they're not shown [].
Why do you want to add them in []?
