Need Help Automating Taxi Booking Workflow with Pabbly Connect
Status: Closed · Asked by fiveways group on · 0 views
Hello everyone,
We operate a UK-based minicab service and are looking to automate our booking process using Pabbly Connect.
Our goal is to create a workflow that works like this:
- A customer submits a booking through our website.
- The booking details are automatically sent to Google Sheets.
- A confirmation email and SMS/WhatsApp message are sent to the customer.
- The booking is forwarded to our dispatch team.
- If possible, we'd also like to notify the assigned driver automatically.
Has anyone built a similar workflow for a taxi or transportation business?
We're also interested in recommendations for the best apps or integrations to use with Pabbly Connect for booking confirmations, driver notifications, and customer communication.
Any workflow examples, templates, or best practices would be greatly appreciated.
Thank you!
Hello Tobias,
Yes, this use case is possible with Pabbly Connect.
To achieve this, your website should support webhooks or have a compatible trigger (such as Elementor Forms, WPForms, Contact Form 7, or any other booking tool that can send data to Pabbly Connect). Whenever a customer submits a booking, the webhook will trigger the workflow automatically.
From there, you can:
Add the booking details to Google Sheets.
Send a confirmation email and SMS/WhatsApp message to the customer.
Forward the booking details to your dispatch team.
Notify the assigned driver automatically, if applicable.
Could you please confirm which platform or booking system your website is built on, and whether it supports webhooks? This will help us suggest the best approach for your setup.
Thanks & Regards,Anushka Sahu
🌐 Pabbly.com
