Pabbly Automation Is Triggering Continuously
Status: Closed · Asked by eduavenir eduavenir on · 0 views
eduavenir eduavenir — Question ·
Hi Pabbly Support Team,
I am facing an issue with my Pabbly automation. The workflow is getting triggered continuously, even though there should not be repeated triggers.
I have checked the automation, but I am unable to identify why it is being triggered repeatedly.
Issue:
  • The automation is triggering continuously.
  • It appears to be hitting the workflow multiple times without the expected new trigger/event.
  • I need your help to identify the reason for these repeated executions.
  • Please check the workflow logs/execution history and let me know what is causing this.
I have attached a screenshot for reference.
Please help me resolve this issue as soon as possible, as it is causing unnecessary workflow executions.
Thank you.
eduavenir eduavenir — Reply ·
eduavenir eduavenir:
Hi Pabbly Support Team, I am facing an issue with my Pabbly automation. The workflow is getting triggered continuously, even though there should not be repeated triggers. I have checked the automation, but I am unable to identify why it is being triggered repeatedly. Issue: The automation is trigg
Contact Number: 7304319268
10.11 Design — Reply ·
yes same issue
Pabbly Support — Reply ·
Hello Eduavenir,
Thank you for reaching out and sharing the details of the issue you are facing. We completely understand the seriousness of the situation and sincerely apologize for the inconvenience caused.
Please note that the current version of Facebook Lead Ads has been deprecated by Meta, which has led to unexpected behavior in the existing integration. Our Technical Team is already aware of this issue and is actively working on a fix.
We assure you that we will inform you immediately once the issue is resolved. In the meantime, we truly appreciate your patience and understanding.
Adeel Akhtar
🌐 Pabbly.com
Mario Somerville — Reply ·
Mismo problema en nuestra cuenta: ~300 flujos afectados.
Tuvimos que desactivarlos todos manualmente esta mañana porque empezaron a reprocesar y duplicar leads históricos. Los leads antiguos se volvieron a enviar a los CRM, Google Sheets y listas de correo de nuestros clientes, sin que hubiera entrado ningún lead nuevo. Los flujos siguen apagados.
@Equipo de Pabbly: ¿pueden indicarnos un plazo estimado para la solución?
Necesitamos saber:
1. ¿Cuándo quedará corregido el disparador de Facebook Lead Ads?
2. Una vez corregido, ¿es seguro reactivar los flujos tal como están, sin que vuelvan a duplicar los históricos? ¿O hay que reconectar o cambiar cada uno a "New Lead (Instant)"?
3. ¿Nos devolverán las tareas consumidas por las ejecuciones duplicadas?
Por favor publiquen una actualización aquí apenas esté resuelto. ¡Gracias!
Sajid Bari — Reply ·
Same issue: IjU3NjYwNTZmMDYzNTA0MzY1MjZiNTUzMzUxMzM1MTYyNTQzNTBmMzQi_pc
Hello Sajid,
Also, once the issue is fixed, the leads that were not received during this period will be processed, so no leads will be missed.
Adeel Akhtar
🌐 Pabbly.com
Hello there,
I would like to inform you that the issue has now been resolved with the Facebook Lead Ads: New Lead trigger. Please check on your end and confirm if the trigger is working as expected.
If the issue still persists, please let us know, and we will be happy to assist you further.
Adeel Akhtar
🌐 Pabbly.com
Hello there,
I hope you’re doing well. I just wanted to follow up regarding my last message.
Adeel Akhtar
🌐 Pabbly.com
Hello there,
I hope this message finds you well. I’m following up on my previous message. Further, this is our last follow-up. This Forum thread will be closed automatically as we have not received a reply. You can start a new thread or email us at support@pabbly.com to raise your concern.
Adeel Akhtar
🌐 Pabbly.com
