Thrivecart upsell is not firing
evgeny
Hey folks,
I've tested live Thrivecart Upsell 3 times - Pabbly is not capturing the webhook.
Need your help to get the integration working.
Cheers,
Evgeny
evgeny
So, I was doing exactly the same steps but in a live version (with $1 for the upsell). It did not catch the hook. I will try to to it now in a test scenario and see if it works.
Supreme
Hey @evgeny
Could you please record a short video on how you are capturing the webhook response of "Upsell"? So that we can look into it and assist you accordingly.
johno
HI, I am having the same issues. I have spent 4 hours and it does not fire the live version of the request nor add to my list. Please assist.
Thanks!
John
Supreme
Hey @johno
Please check out our short recorded video on how you can capture the Thrivecart: Upsell trigger a response.
Further, if you are still not able to capture the webhook response then, let us know how you are capturing the webhook response at your end with the help of a short video. We will then look into it and assist you accordingly.
