Worflow works in test but not when in trigger by lead
Status: Closed · Asked by Andrea Marchetti on · 0 views
Andrea Marchetti — Question ·
This workflow has stopped working after I changed the event that triggers the webhook. It works in “Save and Test” mode, but it doesn’t work in production.
Pabbly Support — Reply ·
Hello Andrea,
Thank you for reaching out.
Since the workflow works in Save & Test but not for live events, this usually means the trigger connection has gone stale or the source app's webhook subscription was dropped after you changed the trigger event. Please try the following:
1. Clone the existing workflow using the Clone option from the workflow menu.
2. Turn OFF the original workflow so you don't have duplicates running.
3. Open the cloned workflow and in the Trigger step, click Refresh Fields, then click Save and Send Test Request exactly once and capture the response.
4. Re-check the field mapping in all subsequent action steps so they still point to the correct trigger fields.
5. Save the workflow and turn it ON.
Also please confirm:
- Which trigger app and trigger event you switched to, and
- That the trigger event type selected in Pabbly matches the actual event you are performing in the source app.
If the issue persists after cloning and re-capturing, please check Task History for errors and verify the trigger app's connection/authentication is still valid. You can also share the workflow URL at support@pabbly.com and grant us permission to access your account so we can investigate further.
Vinay Jain
🌐 Pabbly.comSignature image
Hi Andrea,
Just following up to check whether you had a chance to try the suggested steps. Please let us know if the workflow is now triggering correctly or if you’re still facing the issue.
Vinay Jain
We’re following up on our previous message regarding your query. As we haven’t received a response, this will be our last follow-up, and the thread will be closed automatically.
If you still need assistance, you can email us again at support@pabbly.com to raise your concern.
We would also greatly appreciate it if you could share your feedback on your support experience using the following link: https://bit.ly/3V2Pjia
Vinay Jain
