Workflow Stuck
Your Task History ID
IjU3NjIwNTY5MDYzNTA0MzI1MjY5NTUzYzUxMzY1MTYwNTQzMSI_3D_pc
Dear Experts,
Recently, I found out that my workflow, specifically, Infinity app inside my workflow keeps loading forever. And the fields for mapping are not showing up. It makes my workflow does not work.
I hope you can fix this soon.
Regards,
P.S. I tried on many browsers, already cleared the cache and in Cognito mode, still it didn't work.
Now, I also found out that If I changed the above step(s) then the below step doesn't show data for mapping even though I tried to refresh fields and reload the website, still it doesn't show data at all.
Supreme
Yes, to map the data in your further action steps you need to make sure that you have run the previously added action step at least once to map its API response.
Further, can you please try the Monday.com action step once in your workflow and then try again?
