Smartlead.ai Integration with Pabbly Connect
This documentation offers a comprehensive, step-by-step guide to integrating your Smartlead.ai account with Pabbly Connect. By following these instructions, you can effortlessly establish a seamless connection between the two platforms.
How to authorize Smartlead.ai in Pabbly Connect?
  • Within Pabbly Connect, navigate to the action step and choose "Smartlead.ai" as the action you wish to perform. Select an action event, such as "Add Client".
  • To establish a connection, select "Add New Connection" and if you already have an existing connection, you can opt for "Select Existing Connection" instead.
  • To establish a new connection, select the "Add New Connection" radio button, enter the API Key, and click on the "Save" button.
  • If you already have an existing connection, you can opt for the "Select Existing Connection" radio button and click on the "Save" button.
======================TRIGGERS==============================
Smartlead.ai: Email Sent(Trigger Event)
Please follow below the steps to capture the trigger response for the above-mentioned trigger event:
  • Log in to your Smartlead dashboard.
  • Navigate to the settings page, and on the left panel, select Webhook.
  • Click on "Add Webhook" to create a new webhook.
  • In the popup, enter your webhook name. Copy the provided webhook URL and paste it into the destination URL field.
  • Choose the event 'EMAIL SENT' and then select the campaign from which you wish to retrieve details.
  • To test the webhook, click on the "Send Test To Webhook" button.
  • Once the webhook events are activated on the specified URL, any triggered events will capture the corresponding webhook response.
  • Click on the "Capture Webhook Response" button below and perform a test recording to capture the webhook response here.
Smartlead.ai: Email Open(Trigger Event)
  • Choose the event 'EMAIL OPEN' and then select the campaign from which you wish to retrieve details.
  • Once the webhook events are activated on the specified URL, any triggered events will be captured in the corresponding webhook response.
Smartlead.ai: Email Reply(Trigger Event)
  • Choose the event 'EMAIL REPLY' and then select the campaign from which you wish to retrieve details.
Smartlead.ai: Email Link Click(Trigger Event)
  • Choose the event 'EMAIL LINK CLICK' and then select the campaign from which you wish to retrieve details.
Smartlead.ai: Lead Unsubscribed(Trigger Event)
  • Choose the event 'LEAD UNSUBSCRIBED' and then select the campaign from which you wish to retrieve details.
Smartlead.ai: Lead Category Updated(Trigger Event)
  • Choose the event 'LEAD CATEGORY UPDATED' and then select the campaign from which you wish to retrieve details.
ShailyV
Pro Member
======================ACTIONS==============================
Smartlead.ai: Add Client(Action Event)
Please follow the steps below to add a client for the above-mentioned action event:
  • Use Case: To add a new client to your Smartlead.ai account.
  • Select "Add Client" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Name", "Email", "Permission", "Password" and other required fields.
  • Click on "Save and Send Test Request".
Smartlead.ai: Add Leads to a Campaign by ID(Action Event)
Please follow the steps below to add a lead to a campaign by ID for the above-mentioned action event:
  • Use Case: To add leads to a campaign by ID to your Smartlead.ai account.
  • Select "Add Leads to a Campaign by ID" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Campaign", "Email" and other required fields.
Smartlead.ai: Add an Email Account(Action Event)
Please follow the steps below to add an email account to a campaign for the above-mentioned action event:
  • Use Case: To add an email account to a campaign to your Smartlead.ai account.
  • Select "Add an Email Account" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Campaign", "Email Account" and other required fields.
Smartlead.ai: Add Lead/Domain to Global Block List(Action Event)
Please follow the steps below to add a lead/domain to the global block list for the above-mentioned action event:
  • Use Case: To add lead/domain to the global block list to your Smartlead.ai account.
  • Select "Add Lead/Domain to Global Block List" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Domain Block List", and "Client".
Smartlead.ai: Add/Update Warmup(Action Event)
Please follow the steps below to add/update warmup for the above-mentioned action event:
  • Use Case: To add/update warmup to your Smartlead.ai account.
  • Select "Add/Update Warmup" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Email Account", "Warmup Eabled", and other required fields.
Smartlead.ai: Create Campaign(Action Event)
Please follow the steps below to create a campaign for the above-mentioned action event:
  • Use Case: To create a campaign for your Smartlead.ai account.
  • Select "Create Campaign" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Name", and "Client".
Smartlead.ai: Update Campaign Status(Action Event)
Please follow the steps below to update the campaign status for the above-mentioned action event:
  • Use Case: To update the campaign status for your Smartlead.ai account.
  • Select "Update Campaign Status" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", and "Staus".
Smartlead.ai: Update Lead(Action Event)
Please follow the steps below to update lead details for the above-mentioned action event:
  • Use Case: To update lead details for your Smartlead.ai account.
  • Select "Update Lead" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", "Lead", "Email" and other required fields.
Smartlead.ai: Update Email Account(Action Event)
Please follow the steps below to update your email account for the above-mentioned action event:
  • Use Case: To update the email account for your Smartlead.ai account.
  • Select "Update Email Account" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Email Account" and other required fields.
Smartlead.ai: Updates a Lead's Category(Action Event)
Please follow the steps below to update a lead's category for the above-mentioned action event:
  • Use Case: To update a lead's category for your Smartlead.ai account.
  • Select "Update a Lead's Category" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", "Lead", "Category" and other required fields.
Smartlead.ai: Get Campaign by ID(Action Event)
Please follow the steps below to get the campaign details by it's ID for the above-mentioned action event:
  • Use Case: To get the campaign details for your Smartlead.ai account.
  • Select "Get Campaign by ID" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign".
Smartlead.ai: Get Campaign Analytics(Action Event)
Please follow the steps below to get the campaign analytics for the above-mentioned action event:
  • Use Case: To get campaign analytics for your Smartlead.ai account.
  • Select "Get Campaign Analytics" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
Smartlead.ai: Get Email Account by ID(Action Event)
Please follow the steps below to get email account details by their ID for the above-mentioned action event:
  • Use Case: To get an email account by ID for your Smartlead.ai account.
  • Select "Get Account by ID" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Email Account".
Smartlead.ai: Get all Email Account(Action Event)
Please follow the steps below to get all email account details for the above-mentioned action event:
  • Use Case: To get all email accounts for your Smartlead.ai account.
  • Select "Get all Account" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
Smartlead.ai: List all Leads(Action Event)
Please follow the steps below to list all leads for the above-mentioned action event:
  • Use Case: To list all leads for your Smartlead.ai account.
  • Select "List all Leads" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign" and "Limit".
Smartlead.ai: Pause Lead(Action Event)
Please follow the steps below to pause a lead for the above-mentioned action event:
  • Use Case: To pause a lead of a campaign for your Smartlead.ai account.
  • Select "Pause Lead" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign" and "Lead".
Smartlead.ai: Resume Lead(Action Event)
Please follow the steps below to resume a lead again for the above-mentioned action event:
  • Use Case: To resume a lead again of a campaign for your Smartlead.ai account.
  • Select "Resume Lead" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", "Lead" and other required fields.
Smartlead.ai: Fetch Warmup Statistics(Action Event)
Please follow the steps below to fetch warmup statistics for the above-mentioned action event:
  • Use Case: To fetch warmup statistics for your Smartlead.ai account.
  • Select "Fetch Warmup Statistics" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
Smartlead.ai: Fetch Lead by Email Address(Action Event)
Please follow the steps below to fetch lead by email address for the above-mentioned action event:
  • Use Case: To fetch leads by email address for your Smartlead.ai account.
  • Select "Fetch Lead by Email Address" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Enter "Email " address.
Smartlead.ai: Remove an Email Account(Action Event)
Please follow the steps below to remove an email account for the above-mentioned action event:
  • Use Case: To remove an email account for your Smartlead.ai account.
  • Select "Remove an Email Account" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", and "Email Account".
Smartlead.ai: Delete Campaign(Action Event)
Please follow the steps below to delete a campaign for the above-mentioned action event:
  • Use Case: To delete a campaign for your Smartlead.ai account.
  • Select "Delete a Campaign" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
Smartlead.ai: Delete Lead by Campaign ID(Action Event)
Please follow the steps below to delete a lead by its campaign ID for the above-mentioned action event:
  • Use Case: To delete a lead by its campaign ID for your Smartlead.ai account.
  • Select "Delete Lead by Campaign ID" as an action event, connect your Smartlead.ai account, choose the connection type (either new connection or existing connection), and click the "Save" button (For help with authorization, check out the "How to authorize Smartlead.ai in Pabbly Connect?" section.)
  • Choose "Campaign", and "Lead".
Successful Integration:
Upon completing the above steps, your Smartlead.ai account will now be successfully integrated with Pabbly Connect. You can utilize different actions and triggers according to your purpose. With this integration, you can automate processes through Pabbly Connect, improving your workflow and enhancing your productivity.
If you encounter any issues or require further assistance, feel free to reach out to our support team for help. ([email protected])
Happy integrating!
