ThriveCart Workflow fires in Test mode but not Live mode
Keith Dream
I have a workflow that is triggered on a ThriveCart product purchase.
It adds them to a Zoom meeting and tags them in Mailchimp.
This works fine in ThriveCart test mode, but when I cloned it and set it to Live mode, it is not getting triggered. It also doesn't show up in History.
Can you see what I've done wrong?
Live Mode Workflow: https://connect.pabbly.com/workflow/share/AEhRYwVOUzBWHFQQDm8AJwwbV35TGQBWBGNWRA##
Test mode Workflow: https://connect.pabbly.com/workflow/share/DkYCMF4VBmVRG1cTAV4HZF9LVUZTGQFXVzAJGw##
Keith Dream
For the previous test, I was using a coupon for 100% off to test live. That appears to be the problem.
I made the product $1 and purchased it and the workflow processed. This isn't optimal, but if it is the expected behavior that's good information to know. Is that correct?
Thanks in advance.
Supreme
Hey @Keith Dream
If you cloned the workflow, then you have re-authorize the trigger event and capture the webhook response again in Live mode.
Please try again and let us know if you still get stuck at any step.
Keith Dream
Thanks for the reply. I did re-authorize the trigger event and captured the new webhook response in Live mode. I was able to verify the new information was retrieved when I did that. However purchases didn't trigger the workflow after that when I was testing the purchase in Live mode with a 100% off coupon (so the price came out to $0).
After purchasing with an amount over $0, the trigger did work.
So my question is, does it matter how much the amount of purchase is? This seems strange.
Supreme
Hey @Keith Dream
Kindly try with the minimum amount of 1$ to capture the webhook response.
Keith Dream
Hi @Supreme, yes it does work with $1. So are you confirming that there is a minimum charge required in order for the Workflow to trigger?
I just need to know so I can update my Standard Operating Procedures for new product launches.
Supreme
Hey @Keith Dream
Yes, in terms to set up the Thrivecarts' trigger response in Live Mode, you have to make a real payment of a minimum value of $1. Since it needs to connect with the Trhrivecarts payment page to establish the connection.
